I do Model A/C Plans and Parts.
If you are thinking of developing a small Model Aircraft based business and need a CAD based plan or part files for laser cutting, then go to
http://www.mybloo.com/coosbay/laser/projects.htm
and see an extensive listing of completed projects for customers.
Young or old, have aided in the startup of several home based firms since the late 1970's. Glow power, electric power, Ducted fan, Old Timer, Aerobatic, glider, of 28 inch W.S. to 128 inch W.S. Work is generated from your prototype or sketches, and plotted out here using Autocad by Autodesk.
No, cannot show you a sample work, for that belongs to the customer. By going to the web site noted below, you can however download a one sheet example of a project done several years back. Most everything is generally handled via Internet, at your pace. Use the MAILBOX button to get ahold of me.
William
