RE: gryo question (GY240)
When you give full left/right rudder does the slider hit either the tail hub or tail case? If yes then your servo arm is too long or your linkage isn't centered.
If it doesnt have enough movement to nearly hit the taili case and or hub then its too short.
This is with your rudder end points at 100/100 where they should be for any heading hold gyro.
