RE: GS XUT PRO Thread
I race my xut at my lhs in tenn. and we race hard the xut is right there with the x1crts and losi 8ts i have seen a few gs suts have the same trouble as me if you have seen the jammin it has hinge pins with nuts to keep them in place and uses different toe blocks instead of cams or bushings so when you fit hard the arms have a chance to pop out because of the give in the plastic pieces so i replaced them with alum. braces and have not had any more problem. pick up .32 friday i will let you know what it is like talk later
