ORIGINAL: Edgar Perez
ORIGINAL: d_wheel
Futaba antennas can be routed outside of the fuselage if necessary.
Can you point me to a thread or page that explains this extension of the small antennas?
Nobody said anything about extending the antennas. You mount the RX near the fuselage shell and make holes in the fuselage. Pass the antenna leads through the holes and secure to outside surface.
Remember that the entire length of "antenna" cable is
NOT the antenna, only the last short section which has been stripped of shielding. Have these two short pieces 90 degrees to each other. Positioning of the rest is irrelevant.
