Old 07-14-2007, 11:56 PM
  #72
Mike Connor
Mike Connor's Avatar
Default RE: (Something Fast?) Delta Build Thread
ORIGINAL: ChuckL
I was looking at the side views on your site and I'm not sure a pipe will clear without a riser, I have the straight one piece header and pipe for my 60LX Fire I'm not sure it will clear the center section there may be more room than it appears though.
Your exact setup is what I am considering for my second one. You must of overlooked on my site "The fuse area can be extended down to drop the fuel tank for easy rear exhaust installations." (see pic below) The top is only as high as you build it to clear your setup. It may take me awhile to start that project and I was hoping someone would put some serious power on one soon. If not You will see the video when it happens. [X(] It would be simple to build it like a Dust but I will leave that to someone else.
