Old 07-15-2007, 12:54 AM
  #75
iron eagel
iron eagel's Avatar
Default RE: (Something Fast?) Delta Build Thread
Thanks mike,
I think that with a 91 df it be way to fast for where I fly....
I bet that you could get 200+ out of that setup, even with a bigger airframe.
Just add the extension you have and a 60-70 would fit well and more than enough power. Hmm, make the center section an inch or two wider mount the engine sidewinder totally enclosed within the fuse. Pipe the exhaust and air to a rear dump bet that would honk.
Have you seen:
http://www.shredair.com/fan.html
4 lb thrust...
