...freakin' overspray!
Help!
I'm building a YAK 54 and decided to go with some bright red invasion stripes on the bottom of the wing to help me with my orientation. I was in such a hurry, that I didn't bother to mask off the top of the wing, and there it is, red overspray. I tried some alcohol but it didn't get it off. I'm thinking of some light sanding with a foam sanding block, but not too sure. Here's the paint I used, it's a plastic enamel made by Valspar. I found it at Lowe's building supply for a plastic cowl I painted on a different airplane. I tried it on some scrap depron, and it works! It is super-critical that the first coat be applied as lightly as possible. I mean, just breathe it on. I hold the can about two feet above the surface and let the mist fall on the part. Let it dry for 10 minutes, then give it a slightly heavier spray. The third coat is the money coat ,you can give it a final heavier spray, giving it a even color. I've never had depron melt with this paint or method. It only comes in a few basic colors, but it's cheap and covers very well. Back to my problem, any ideas on how to get the overspray off? I don't want to do any decorating on top of the wing if I can help it. I'm trying to keep this plane as light as possible. And what a plane! I'm very impressed with the quality of this model. I flew a buddy's Airfoilz YAK and had to have one. Very nice details and easy to build. Keep up the great work.
Jesse
