RCU Forums - View Single Post - Battery cycling
Old 07-18-2007 | 03:07 PM
opjose's Avatar
opjose
Default RE: Battery cycling
ORIGINAL: fjaust
I had a bit of a dig around the net and couldn't find any charge leads with that little white connector that the JR TX batteries use so is there some way of making up my own lead if I have to?
Thanks, FJ
In searching around I did find several MUCH higher capacity batteries that already come with the JR leads.
I believe these were in the 1800mAh-2000mAh range or above.
However you can go one better if you know how to solder.
Just clip the wires off an old spent battery.
Cut the wires, stript the ends. Twist each one and "tin" them with a bit of solder.
Do this to a new higher capacity battery pack... just DO NOT let the two wires touch each other at any point!
Put a piece of heat shrink tubing on to the wires and remove from the area you are about to heat.
Twist the like colors together and heat with your iron until the solder runs.
Let cool, then slide the heat shrink tubing in place and hit it with a heat gun.
Repeat for the other side and you're done.
