RE: Is "Wood Glue" dead?
by the way I still use titebond or even elmers glue all.tried hot stuff when it first came out $16.00 for 2 little bottles,it was okay if you fit the joints properly but when it kicked made my eyes water,I still use it sparingly,keep it uin the freezer still good after 10 years.I built a falcon 56 in 1970 using elmers glue all,all the joints are still nice and tight,the silk covering as dry rotted and torn,but the air frame is still airworthy,will be stripping off the old silk and recover with a plastic film,back then that falcon weighed 5 plus pounds,lots of coats of dope to seal the weave made it heavy.
