I have my Avistar all setup to go.
I have all the throws set for max.
The problem is in the Aileron section.
I have full throw on one side only.
Both up and down.
I spent several hours adjusting the ball links.
I then resorted to removing the servo control arm. and repositioned it on the shaft
I can get even throws of 3/8th on an inch.
I need 3/8th down and a half inch up.
But when I try for the half inch all I can do is get it on one side.
I removed the wing and saw that one of the rods that come out from the bottom seemed to have a restricted area of movment.
I cleaned out the hole and that gave a bit more of up and down on that side of the wing.
It seems that the one aileron does not have enough movment.
If i keep the 3/8th setting I have nice even throws.
I still can keep my trim nice and even and thats not a problem.
I'm installing the 46 engine on it and want all the control I can get.
Seems the one side is binding.
Any suggestions?
Sure hate to tear thaat beautiful wing apart
