Increasing throws?
I am interested in increasing my rudder throw on my World Supersport .40. If I move the clevis closer to the control surface it lengthens the control link.
However, doesn't it then require you to recenter the surface either by trimming or by manually trimming (resetting the linkage on the servo)?
So, aren't you back to square one again? Using the outside hole on the horn makes sense, or making sure your horn is setup for the neutral of the servo also makes sense to me to lengthen your throw.
I just don't see how moving the clevis out will lengthen the throw.
