RE: Micro Cessna 210 RTF Electric
Hey guys, prior to performing surgery on the plane, you might want to move the linkage. The farther out you go the more movement you get. So adding more elevator should make a loop easier. Adding more rudder will speed up turns.
I moved the linkage and still need more control. I added a 1/4 inch to the rudder and that helped but I hate to add weight. I got mine down to 16.7 grams and I can tell the difference. By the way, the closer the linkage to the flap, the farther it moves. Right ? My rudder linkage was already there.
