Originally posted by FLYBOY
You guys are burning the wrong clear piece to the model. The plastic backing will make you sick!
Funny you mentioned that. That was the first time using clear monokote for me and I did have a problem sometimes figuring out which was which. They should put some kind of pattern print on the throw away side. I eventually realized that the monokote would always curl around the clear backing so that helped me out a lot.
Although I don't have a headache now, I still feel weak and run down. I'm not sure if I can still attribute it to the fumes, but I'm not normally a pretty energetic guy.
