mini review- My Hyperflea
Thought I would so somewhat of a mini review!
What plane can slow down to 3mph, or wizz across the sky at 50mph? I was trying to find the one wing that would meat my expectations, and found the Hyperflea from [link=http://superflyrc.com/]superflyrc[/link]. It is made out of EPP, weighs 6.6oz, and has a thrust ratio of almost 2:1.
The build was very easy, using Hot Glue!! It know what your thinking, hot glue But it works GREAT, the hinges were even made out of hot glue, and the hold up perfectly. I have flown it so much this past week. Flying about 3ft off the ground, doing harriers is a blast. It slows down nicely, and when you want to go fast, just push on the throttle, and the speed range is amazing.
It came in a block of foam, with the cut wing halves, and elevons.
