RCU Forums - View Single Post - So I Got A Nemisis And Im Takeing It To The Track
Old 08-01-2007, 04:27 PM
blackrain
blackrain's Avatar
Default RE: So I Got A Nemisis And Im Takeing It To The Track
If you plan on racing the stock engine, check out some of the setups in area 51 on Cen website and look in PPman section he has some sweet tips and wicked nemesis race videos. I tried 40 series size tires with stock engine you will loose a lot of topend but for a small track you should be fine. If anything check and see if yours have the upraded axles the original ones were weak, the new ones use a very small set screw. The truck is basically bullet proof after that. im currently shopping around to buy a second one also i beleive i still have modded engine mount pics
