RE: 9CAP forgets trainer settings
Don.
Do you have a 9CA????
I am using 2 9CAP Tx,
all 8 channels: Landing gear, Flaps, Brakes on the wheels, and Canard mixed from Elevator.
INH means trainer mode is switched off.
When you have it ON and toggle the trainer switch the screen will it read ON or OFF.
Now then you have the options for each channel: NORM FUNC OFF
I had All 8 set to FUNC
Next time out 1-4 were FUNC 5-8 were OFF.
Also with different plane, a 4 channel trainer in fact, I did the set it up, and all is good for the flight. Come back after lunch and the switch is disabled: INH
