ORIGINAL: holinger91
takenotes: the compression is good
Patrick: ill check the linkage tomorrow... i've never checked that before so its a possibility.
thanks for the quick suggestions =D keep em comin... theres no way im giving in and going to the lhs to have the fix it for me -_-
hey man theres nothing wrong with goin to the LHS, just don't let them fix it for you have them teach you how to fix. IM pretty sure your problem is your idle screw make it so when you look in the carb. there is a 1 1/2 mm gap
