RCU Forums - View Single Post - New Great Planes Revolver
Old 08-10-2007, 04:48 PM
  #47
Kostas1
Kostas1's Avatar
Default RE: New Great Planes Revolver
ORIGINAL: 150flyer
Running an OS .55AX. I have two on two other planes. Love the engine. The plane balanced perfectly using the .55AX and placing the battery in the recommended spot under the cowl. You can see there is plenty of room to work inside the plane and many other places to mount a battery to acheive the correct CG with various other engines.
150flyer
THANK"S FOR UR EXCELLENT PICS!
I wish they were oversized (hi-res) to use them as backgrounds!
So far so....good!
Quality as you owners say is excellent!
Someone mentiuoned about a gap between fuse-wing!
Is that acceptable?
Also,
with an OS 55AX and 11x6 APC?
Will it be ok=====>> f-a-s-t ???
Konstantinos
