ORIGINAL: Hesco Racing
I dont see any slotting of your mounts. How sure are you that it is in line with the cable tube. Are you going to run a larger diameter cable too handle the extra power. What are you going to do to the hull's aerodynamics to handle the extra power.
here's the final set-up pic's, inside of the hull coated by epoxy, cable alignment to the engine, 3/16 cable diameter is enough for .46. a .60-.90 pipe as recommended for the engine.
i think this boat can handle with stability in higher 40ish and 50ish, coz it was pretty stable when it was stock and running in 40ish,,kinda excited though what speed and stability will get
