RCU Forums - View Single Post - Showtime 50 anyone?
Old 08-14-2007, 10:28 PM
  #135
waross
Default RE: Showtime 50 anyone?
I carefully drilled a third hole in the rear of the tank at the top and then put a plastic fitting in using some plastic pipe glue plumbers use. Then put a fuel dot on the side attaching the hose to the third hole. Very clean set up and works very well without forcing fuel into the carb.
