RCU Forums - View Single Post - Best Engine for Ultra Stick 60
Old 08-16-2007 | 03:49 PM
  #35
AA5BY
Default RE: Best Engine for Ultra Stick 60
Duke... pretty radical setup... a couple of questions.
How much does it weigh?
When doing harrier landings, are you holding elevator and glide sloping with the throttle or do you establish a throttle setting you like and bring it in mostly with elevator?
Do you use mix when doing harrier landings or just crow?
I've got the US 120 lite and same motor. My harrier landings using crow aren't quite as radical as yours. My throws are not quite full position however, do I want to crank em some more?
I've not landed with the mix on as it increases the roll rate a bit more than I like for landings. My mix switch unfortunately turns on both roll and pitch mixing. Does the pitch mixing play into getting good harrier landings? If so, I may reduce the roll mix numbers as they can always be boosted by the dual rate switch.
Great video...thanks for it and for any advice you may have.
