RCU Forums - View Single Post - JR Charging Plug Mount
Old 08-17-2007, 10:09 PM
rcacro
Default RE: JR Charging Plug Mount
The JR charging plug mount can be made to work. It is necessary to glue the plug into the mount as you suggested. I use epoxy for this. Insert the charger plug into the mount to keep it lined up until the epoxy hardens.
Another thing that helps is to bevel the inside edge of the charger plug so that it does not catch on the the switch harness socket. A #11 xacto knife blade works well for this. All that is necessary is to remove the sharp corner on the plug. Do the same thing to the plug on your voltmeter.
