Old 03-15-2003, 09:35 PM
radiocontrol
Default Mounting an engine inverted.
Thanks. I appreciate the input from everyone. I have seen one instance where a pilot mounted his engine sideways on the UCD. I assume the overall beauty of the plane would be better served if the engine is mounted inverted as intended. I will check the height of the tank vs. the carb very carefully. Can someone explain what an inboard glow system is? And what is a Cline regulator?
Radiocontrol
