RCU Forums - View Single Post - CX2:Flybar Weights-Lock Collars Source?
Old 08-19-2007 | 08:52 PM
Wolfpackin's Avatar
Wolfpackin
Default RE: CX2:Flybar Weights-Lock Collars Source?
Thanks Selime,
I do have an ACE Hardware nearby in Vail; I will try them.
Soloboss,
Thank you, I know what to look for if the above doesn't work out. Probably Tower Hobbies or the like will have them.
Hey, question for ya. I tried to PM you but I don't think I was successful. It seems I have more difficulty with this crazy internet forum stuff than I do flying, repairing and modifying an RC helicopter.
Anyway, in your Overall CX/CX2 Setup paper you state that the flybar linkage must be turned a full 360 degrees because it is directional. The manual states that the linkage can be turned in half or full turns. Any idea which is correct?
BTW, I have been flying with the Dynam Vortex flybar which had to use the bottom half of the linkage from the stock part (The DV loop was too small to fit around the CX2's ball). It was flying great until a minor incident that broke both lower blades. I replaced them, and the uppers, but in order to get back to where I was I had to turn that bottom, stock, linkage one half turn from where it was to get back on track.
