RCU Forums - View Single Post - Fastest engine
Old 08-21-2007 | 12:18 PM
Oliver_Klozov
Default RE: Fastest engine
You can use yokohama geolanders with a good amount of hobby shop glue on the bead to keep them on the tires. The geolanders are bigger than anacondas so it will increase your speed. If you get fresh tires before you put them on put a layer or two of DUCT tape inside the tire to keep the tire from turning into pizza cutters at high speed.
