RE: New Great Planes Revolver
Well, i started puting together my Revolver and it is going fairly easy the only thing I didn't like was I had to spend about 2 hours getting all of the wrinkles out. It has been 90 to 100 degrees here and that is probably why. On one of the wheel pants, the bind nuts were rusty and when I put the small bolts in them they both broke inside !! I'll have to retrofit new blind nuts in there. A simple job is taking me over an hour. Do you guys notice that there are TWO holes for the rudder linkage? It doesn't say anything about a pull pull system in the manual. I didn't notice it untill it was almost put together. And what about the gapsosis in the leading edge of the wing where it meets the fuselage. What are you guys doing about that? I don't think that this will hamper flight performance because it is only about 1/16".
Jeff
