RE: Engine vibration effect on LiOn?
Vibration effects Lithions the same way it effects any other battery. Too much is bad, mostly for the wire connections. Sounds more like you had a bad cell or left the switch turned on. If you're using a Reliaswitch unplg the batteries when they will be stored for more than a day or so.
