ORIGINAL: patsyw26
Thanks--------and what paint are you going to use? Color? Please post how the sound does when you put in water!
patsy ill be using a grey primer for the first coat then a lighter grey from the flood holes upwards just below the deck, also ill be putting yellow lines on the sail and the deck as this is how they would have looked when part of the training floatilla near the end of the war see pic, just i wanted to be different with this one, the last one i built was as per robbes specifications hope this helps
