RE: maxamps
You chose to purchase loose cells and make them into full packs yourself. In doing so you take full responsibility for how that pack is constucted and how it performs. We can not be held accountable for any problems that may occur when an individual purchases and decides to try and make their own packs. Our in shop welding system has welded thousands of packs with no trouble and has proven that it is by far the best way to weld the tabs together at this time. You can sit and bad mouth us all you want and say how you work here and do this until your blue in the face. It still, no matter what you do or say comes down to............................
You made this pack yourself and you are the only one who has had this problem. Which means "your" welding system has failed. And with all of the other posts from others here, it's safe to say that everyone agrees with us.
We Cannot Warranty the loose cells. When loose cells are purchased the buyer takes full responsibility at the time of purchase.
If you'd like feel free to sign up at MaxAmps.com and purchase our packs already made. They all come with a 30 day return policy and a 3yr/300 cycle warranty can also be purchased. This way you'll know the pack was made right from the start.
Case Closed
Jason
