RCU Forums - View Single Post - Remote glow driver help
Old 03-17-2003, 09:55 PM
CafeenMan
Default Remote glow driver help
You can put an eye lug on the ground lead and bolt it on using the the engine mounting bolts. The other end can simply be a small loop of wire with a kink in it that clips on the glow plug post.
At the other end you can use an 1/8" headphone jack. I don't know the actual name of it. The system is very easy to make, inexpensive and reliable. I couldn't begin to tell you how to make a head-lock type glow plug clip. If that's what you want, you may as well buy a commercially made unit.
