RE: Engine installation help needed!
Yes. If you mount the engine central on the firewall but you introduce some side thrust, then the prop driver won't be central as it exits the cowl. So in this case you need to mount the engine off center on the firewall. If you add down thrust, you have to mount the engine slightly high on the firewall for the same reason.
hope this helps
/colin
