RCU Forums - View Single Post - 4.8v to 6.0v
Thread: 4.8v to 6.0v
Old 09-01-2007 | 07:35 AM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: 4.8v to 6.0v
some digitals specify the operating voltage... for a reason I'm sure.
As the voltage goes up the dead band gets narrower. Some digitals, specifically helicopter tail rotor servos like the 9253, 9254, 9251 and 9256 have a very narrow dead band and operate at a much higher frame rate (270hz or 333hz) when hooked to a gyro or rpm governorn vice the standard reciever output which is 70hz and will cause them to over heat and fail.
