RE: Some diff help?
Make shure you got all your washers behind your spyder gears and you didn't double up on one...also check to make shure your pins set right in your bevel gears...and when all checks out ok ....remember you have to brake in new diff's.....IMO...I would go with the 7k oil in the front diff....good luck...[8D]
