RE: Battery Mod
hey nemo what is the mah on those? also what is the name of the pack id like to get one? is it a 2/3aa size? with 6 cells? also seems as if it would be 7.2 volts instead of 4.8 is that too hot for the sub? 6 cells x 1.2 . seeems like a 2/3aa or 2/4aa with 5 cells would be perfect unless you arent having any probs with your current setup.
p.s. is the sub also modded with the 6 volts going to the motors like in the mod manual? man if so that sub probably screams under water. thanks jeff
