RE: Carden 40% Edge 540 build ( first time)
Just for future reference . . . should you ever again find yourself needing to undo parts that have been epoxied, except for foam, use your covering heat gun to heat the glue joint. You'll be able to simply peel the pieces apart without any damage to the wood.
t
