RE: windows and fuel filter valves
Don't know about the windows..
but don't use one of those spring loaded, cuts of fuel to the carb when you fill fuel dots...they leak air after a short time and you'll have a dickens of a time finding that leak..(dickens of a time? ) just get a fuel dot that is a fitting, where the fill line passes through the fitting and is held in place by a stopper and friction. When you want to fill just remove line and stopper.
