X9303 setup help
Hi everyone, I'm having some difficulty in setting my X9303 . The airframe is a 40% Carden 330 with 8611a & 8711 servos
I'm having trouble setting up multiple wing and stab servos. when I get them working correctly I cant seem to make the trim also work. My plan was to use the Flaperon setup for the ailerons, use those two servos as the right and left panel master. I would the slave the two other servos to each other servo.. is this the correct way ? I thought I was close but then I cant figure out how to disable the flap switch I would appreciate any recommendations on how to set this radio up.. I'm coming from a 14MZ and things are way different
