RCU Forums - View Single Post - Problem with OWB.
Old 09-11-2007 | 08:10 PM
gotmonkeys
Default RE: Problem with OWB.
One other thing you may want to double check is the o-ring on the backplate. If it is ripped or torn or in bad shape it could be sucking air and that will cuase the engine to run lean and over heat.
