RE: P-39 Airacobra / Global Quality Kits Build
I measured the copies of the plans and compared them to the original set and they are pretty, pretty close. So I went ahead with using the copies.
Horizontal & vertical stabs went together easily. I added several extra supports in the middle to help fill the space in preparation for the Flite-Metal.
I've laid out the fuselage side. The fuselage it quite warped. Hopefully it won't cause a problem.
