RE: Mid tank Mod finished + engine head air leak?Pics/videos!
I also happen to have an issue on leaks. I recall after I cleaned the engine head I did not thoroughly tighten one of the screws. While the engine is running, I can see some oil bursting below the engine head and staining the manifold. It stained the manifold with a redish-like color.
After I tighten the screws using the 4-way direction instructed in the Manual, I no longer have leaks.
