RE: Air Leak Question??
I hope its the same as the hpi i would rather use their carb then another axial. It sucks that this stuff is made so poorly dont get me wrong the engine flies but if i was a noob it would be extremly hard to not overheat the engine and tottaly give up on tuning it. Its impossible to tune if i loosen my bottom end needle on my other engines they will load up with fuel and stall and puff smoke/bog. With this engine i knew it was an air leak cause when i finally got it running kinda ok the bottom end needle was still to far out , far from flush settings. The only time that part of the carb doesnt leak is at full throttle and that is ok when i run it i have good power and smoke. Anyone else have any ideas???
