RE: Aquacraft Hammer with Brushless 8L motor
I did not know the reef racer prop fit also. thanks for the info. Right now i have the stock prop which is 30mm and the miss bud prop which is 32mm and also fits. I know the setup would be ok with either of these two props. I have run a 4436rpm 8s motor on the miss bud prop with a 2S lipo and it was fine. Everything got a little warm, but prob in the 110-120 deg range which is acceptable considering I was doing a lot of starting and stopping and the water cooling was not effectively working. This is the L motor with more torque and a lower rpm/volt by quite a bit. So I was looking at something bigger than a 32mm prop, but maybe not as big as the 40mm prop.
