RE: Hellfire Engine Problems
You were running at the track with a half of a tank run through it? Did you not break in the engine?
If the motor will not turn over with the plug pulled, I think you mave have just learned a couple hundred dollar lesson in reading the directions.
It sounds like you should just take it back to the shop where you bought it and ask for help.
