RCU Forums - View Single Post - Warped pieces in kit
Old 09-26-2007 | 07:27 AM
bkdavy's Avatar
bkdavy
Default RE: Warped pieces in kit
If you're concerned about ensuring the fuselage remains straight, use a slow curing glue (titebond or elmers carpenters glue), use lots of pins and clamps to hold things in position while the glue cures, and consider adding some triangle stock along the joints to add support, particularly where plywood joins plywood at a 90 degree angle (fuselage sides, formers). The weight added will be minimal, but the strength gains will be substantial, and it will be more resistant to future warping.
Brad
