Bomb Drop
I have used the plastic eggs too, I glued a little loop onto it, made a C shaped piece that I glued to the bottom of the plane, cut a hole for a servo to mount into the bottom of the plane, and took a little piece of wire and went from the servo to the C, when you flip the switch one way itll pull the wire out of the one half of the C and let the bomb go. get it?
