RCU Forums - View Single Post - Showtime 50 anyone?
Old 09-27-2007, 02:20 PM
  #180
jeanyves0922
Default RE: Showtime 50 anyone?
ORIGINAL: rmazuera
Since I did not install the tank that came with the plane, I covered the hole with a 1/32" ply and also closed the original holes for the engine support. Then fuelproofed everything with a coat of epoxy/alcohol mix brushed all over the firewall. Don't think the firewall is 5/16". It is less, Maybe 1/4" in 2 1/8" layers. Only the center section has the second layer.
RMazuera,
How did you manage to remove the blind nuts from the firewall without destroying it? Mine seem to be expoxied.
