RCU Forums - View Single Post - Showtime 50 anyone?
Old 09-27-2007, 03:21 PM
  #181
RodanAZ
Default RE: Showtime 50 anyone?
You can use a soldering iron on the outside of the blind nut to heat it up. This will break down the expoy and allow you to press the nut out. One of them has a former behind it, so you will not be able to get it out.
It's also a good idea to get some epoxy in around the landing gear mount area. I did this and the plane had a rough landing after throwing a prop that I think might have damaged it if I hadn't beefed it up.
I've got almost two gallons through mine now, and I really like this plane! It's definitely more pattern than 3D, but I like it! Once I finish off my second gallon, I'll start experimenting with props to find the ideal setup for my altitude and flying....
