Needle Valve Extension
I have a Webra 1.20 Speed engine. The high speed needle valve has a slot for a screw driver instead of the normal hole for an extension. Besides drilling a hole in the needle valve, is there a way to make a needle valve extension so that I don't have to use a screw driver to adjust the top end while the engine is running a top speed (dangerous task to find the slot with your fingers so close to the prop)?
