Old 03-29-2003, 10:30 PM
Hurri
Default radio interference, flying wires, wing rigging.
I have some 4 WW1 bipes , some have total of 6 pull wires , [4 elev; 2 rudd;] I use plastic coated fishing wire , 60, 80 lb test . If the wires rub on each other it is not metal on metal so no interferance . Sleeves on the ends are crimped , Also put the antenna on the very bottom of the fuse , in a plastic tube , that way as you look up from the tx when flying , the antenn; is below the control wires . There are control wires for elev; rudd; & also loads of flying wires , never even a glitch in 15 years of big bipes .
