ORIGINAL: JB COMP
Ok, I'm not aure if this is the right place or not.
I need to get some info on a 4-stroke nitro RC plane engine. the good the bad, maintance, how long do they last, what kind of temps to run it at, basicly anythin and everything. I run nitro cars, but I look and modded one to fit a 4-stroke plane engine.
so any help you'll can give would be great.
They have a long life in a airplane, where cooling air is abundant. OS made two fourstroke models for kyosho cars and they used small belt driven fans to engine temps under control. The OS car engines were based on airplane engines but had high RPM cams and much stronger valve springs to keep valves from floating during high revs. This is where you are going to have problems with a airplane engine, when your car drive train unloads and rpms skyrocket, your engine will be damaged. This rarely happens in a airplane because even a small prop will still load the engine enough to keep the engine from completely unloading.
If you are going fourstroke, you should at least look for one of the OS fourstroke car engines because they are better suited for the punishment of a car.
